Saltar al contenido principal
How to fix TC Electronic Level Pilot static noise
Qué necesitas
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: paso 1, imagen 1 de 1
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: paso 2, imagen 1 de 1
    • Spray the small opening there with some multi-purpose oil.
Conclusión
11 personas más completaron esta guía.
6 comentarios
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - Contestar
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - Contestar
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - Contestar
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - Contestar
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 32
Todo El Tiempo: 5,677
