Introducción
Nothing special, just to open the level pilot and repair it.
Qué necesitas
The bottom rubber base can be removed
11 personas más completaron esta guía.
6 comentarios
Not a good idea. Oil will &&^& it up dah.
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
Yes, use DeOxit or some similar contact cleaner
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
