Saltar al contenido principal
How to fix Nintendo Switch Joy-Con_Drift
Qué necesitas
  1. How to fix Nintendo Switch Joy-Con_Drift, Before you start: paso 1, imagen 1 de 1
    • Even if you don't touch the joystick, it will input directions.
  2. How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 2, imagen 1 de 1
    • Raise the metal claw next to the joystick. This part will break due to metal fatigue when trying to restore it.
  3. How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 3, imagen 1 de 1
    • The spring and white plastic parts come off when the back plate is removed.
  4. How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 4, imagen 1 de 2 How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 4, imagen 2 de 2
    • Location of metal ring and white plastic parts
  5. How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 5, imagen 1 de 3 How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 5, imagen 2 de 3 How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 5, imagen 3 de 3
    • Clean the matte black areas with gloss with a cotton swab. *The change in the resistance value (black part) with the silver contact can be read with the position information.
  6. How to fix Nintendo Switch Joy-Con_Drift, Ver1: paso 6, imagen 1 de 1
    • Put the metal parts back in their original positions with the springs and white plastic parts, and attach them to Joy-con. (The metal nails in the picture broke when I tried to restore them.)
  7. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 7, imagen 1 de 2 How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 7, imagen 2 de 2
    • The metal press shape is different.
  8. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 8, imagen 1 de 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 8, imagen 2 de 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 8, imagen 3 de 3
    • Use sharp-nose pliers and straighten the bent hinge part.
  9. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 9, imagen 1 de 1
    • Use a precision screwdriver (minus) to remove it while raising the nail.
    • Remove without deforming, leaving the elasticity of the metal
  10. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 10, imagen 1 de 1
    • Insert the screwdriver slowly and remove the metal frame. Be careful because there is a spring
  11. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 11, imagen 1 de 1
    • Disassembled parts springs, metal washers, parts for push button, film substrate, metal frame
    • The metal frame is greased, so do not clean it here. (Wipe here to generate plastic powder.)
    • As expected, it may not be greased if it is not a genuine joystick. In that case, it is recommended to apply any grease.
  12. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 12, imagen 1 de 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 12, imagen 2 de 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 12, imagen 3 de 3
    • The black part is a sensor that reads the resistance value. There is a line-like gloss here, so use a cotton swab to clean it.
    • CAUTION Wipe the metal terminals with a cotton swab dipped in alcohol. Be careful as it bends easily.
  13. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 13, imagen 1 de 2 How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 13, imagen 2 de 2
    • Attach the washer and push-button parts using tweezers.
  14. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 14, imagen 1 de 1
    • Place the spring on the washer
  15. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 15, imagen 1 de 1
    • Place the film substrate on the metal frame. Since there are two claws, please check the position and put it on.
  16. How to fix Nintendo Switch Joy-Con_Drift, Ver2: paso 16, imagen 1 de 1
    • The part using the radio pliers at the beginning cannot be removed without doing anything, so let's leave it as it is so that it can be easily removed when disassembling next.
  17. How to fix Nintendo Switch Joy-Con_Drift: paso 17, imagen 1 de 1
    • Since the metal frame is fixed with the plastic parts when returning it, it does not hinder the operation.
    • The photo is from Ver1
  18. How to fix Nintendo Switch Joy-Con_Drift, Photo after work: paso 18, imagen 1 de 1
    • The joystick is back in action!
Conclusión
To reassemble your device, perform these steps in reverse order.
5 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
jp en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
syusan
Miembro Desde 05/25/20
528 Reputación
2 Guías creadas
Un comentario
Great Guide, works like a dream
lou reed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 45
Todo El Tiempo: 6,254
