Introducción
After a couple of thousands clicks the Anywhere MX Mouse develops a phantom double click. This is due to a grove that develops on the inside of the button. It can be fixed with a piece of tape.
Qué necesitas
The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
60 personas más completaron esta guía.
40 comentarios
Thank you for this hint! It worked perfectly
Thank you, it worked!
Thank you for this guide! Got my mouse working and saved me some money :)
