Saltar al contenido principal
How to fix Bad GPS and Cell Phone Signal for LG G2
Qué necesitas
Resumen del Video
  1. How to fix Bad GPS and Cell Phone Signal for LG G2, How to fix Bad GPS and Cell Phone Signal for LG G2: paso 1, imagen 1 de 1
    • Tools required.
  2. How to fix Bad GPS and Cell Phone Signal for LG G2: paso 2, imagen 1 de 1
    • Open the back panel and locate these three connectors.
  3. How to fix Bad GPS and Cell Phone Signal for LG G2: paso 3, imagen 1 de 1
    • Gently lift up all three connectors.
  4. How to fix Bad GPS and Cell Phone Signal for LG G2: paso 4, imagen 1 de 1
    • Cut a piece of thin cardboard.
  5. How to fix Bad GPS and Cell Phone Signal for LG G2: paso 5, imagen 1 de 1
    • Cut the pieces close to the size of the connectors.
  6. How to fix Bad GPS and Cell Phone Signal for LG G2: paso 6, imagen 1 de 1
    • Place the cardboard pieces under all three connectors.
  7. How to fix Bad GPS and Cell Phone Signal for LG G2: paso 7, imagen 1 de 1
    • Gently press down the conectors.
  8. How to fix Bad GPS and Cell Phone Signal for LG G2: paso 8, imagen 1 de 1
    • Close the back panel.
Conclusión
20 personas más completaron esta guía.
bonetti
Miembro Desde 07/09/15
610 Reputación
1 Guía escrita
7Guía Comentarios
THANK YOU THANK YOU! Gps locks in seconds and stays locked instead of locking then unlocking after 2 minutes like before. Big ups!
Garrett Wayne - Contestar
Vielen Dank, GPS funktioniert bei mir wieder richtig gut. Einer der 3 Kontakte war gut verklebt. Er musste mit einem Teppichmesser unterschnitten werden, was äusserste Vorsicht erfordert.
Peter - Contestar
GPS bug I encountered: being from time to time located 50m northward (upsetting when the mains highways are E-W). Working great for the moment :-)
A. Delille - Contestar
This solution saved me! Thanks a lot.
ogrean florin - Contestar
Sir... Thank you! I was considering to buy another phone, but i love my LGG3 D855 this worked for me too.
I would hug you if i could, thank you! (Hail from Brazil!)
leandrowsp - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 74,279
