Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to empty and clean Rival 16131 Toaster crumb tray
Qué necesitas
  1. How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: paso 1, imagen 1 de 2 How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: paso 1, imagen 2 de 2
    • To open the crumb tray, pinch the lever in the photo.
    • If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
  2. How to empty and clean Rival 16131 Toaster crumb tray: paso 2, imagen 1 de 1
    • Now that the tray is exposed, it is possible to clean the face here.
    • Try to not let water get into the toaster as this may damage the heating coil.
    • If the tray can not be cleaned simply by opening it, keep going through the guide to fully remove it.
  3. How to empty and clean Rival 16131 Toaster crumb tray: paso 3, imagen 1 de 3 How to empty and clean Rival 16131 Toaster crumb tray: paso 3, imagen 2 de 3 How to empty and clean Rival 16131 Toaster crumb tray: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • To remove the tray, the metal hinges must be bent up.
    • While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up.
    • Remove the tray and clean.
Conclusión
Grant Haug
Miembro Desde 09/26/12
148 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 2-8, Propen Fall 2012 Miembro de Cal Poly, Team 2-8, Propen Fall 2012
CPSU-PROPEN-F12S2G8
Miembros de 5
6 Guías creadas
1Guía Comentario
Thanks! This was helpful. :)
Tracy Emmanuel - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 36
Todo El Tiempo: 3,698
