Saltar al contenido principal
How to easily fix a Xbox 360 drive that wont open.
Qué necesitas
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: paso 1, imagen 1 de 2 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: paso 1, imagen 2 de 2
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: paso 2, imagen 1 de 1
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: paso 3, imagen 1 de 2 How to easily fix a Xbox 360 drive that wont open.: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: paso 4, imagen 1 de 2 How to easily fix a Xbox 360 drive that wont open.: paso 4, imagen 2 de 2
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: paso 5, imagen 1 de 1
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: paso 6, imagen 1 de 2 How to easily fix a Xbox 360 drive that wont open.: paso 6, imagen 2 de 2
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
Conclusión
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
15 personas más completaron esta guía.
Matt Weatherly
Miembro Desde 09/16/12
1,305 Reputación
2 Guías creadas
8 comentarios
the picture of the exbox is not mine
dongwillows - Contestar
the picture you show is not my console
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - Contestar
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - Contestar
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 20
Ultimos 30 días: 108
Todo El Tiempo: 11,206
