Saltar al contenido principal
How to downgrade iPhone 4S / iPad 2 to iOS 6.1.3
  1. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Enter kDFU mode: paso 1, imagen 1 de 1
    • Launch Cydia and add repo: http://repo.tihmstar.net to enter KDFU mode (Please check the detailed tutorial). Only when your iDevice is in KDFU mode, you can downgrade to iOS 6.1.3. Please make sure your iDevice is in KDFU mode, then continue to downgrade.
  2. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Download custom firmware.: paso 2, imagen 1 de 1
  3. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, 3uTools proflash: paso 3, imagen 1 de 1
    • Launch 3uTools and go to “Flash & JB” -> “Pro Flash”, click “Import Firmware” and select the firmware you have already downgraded.
  4. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Go "Flash": paso 4, imagen 1 de 1
    • After you import the firmware, click “Flash” on the right bar.
  5. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Wait till the process is finished: paso 5, imagen 1 de 2 How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Wait till the process is finished: paso 5, imagen 2 de 2
    • Now 3uTools will automatically flash your iDevice, please confirm the connection between your iDevice and pc.
  6. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Finish: paso 6, imagen 1 de 1
    • Normally, it would take around 10 minutes to downgrade.
Conclusión
22 personas más completaron esta guía.
Grace
Miembro Desde 02/09/17
1,723 Reputación
1 Guía escrita
10 comentarios
Great guide! I haven’t tried it out yet, but it looks great!
Naples - Contestar
Thanks this worked perfectly!
Joseph - Contestar
This is a very poor guide, well below IfixIt standards. Perhaps experienced hackers might follow these steps
but if I was a hacker would I need this. Which Cydia,? Where to download? Download it onto the target device or a laptop connected to
the target device. C’mon guys this is seriously sloppy work.
kevin hunter - Contestar
firstly you need to know how to upgrade your device to 9.3.5 for iphone 4s only, you can follow apples’s guide. then you need to jailbreak it a quick google search will lead you to a fast guide on how to jailbreak it. then come back here to follow the instructions on how to to downgrade it to 6.1.3. just use google people <3
WOLFRANDMAC Is On -
This guide is not intended towards the average person. If you are interested in completed what is done here, you should research more into this, using other sites. Once you can get the hang of it, im sure you’ll love it. (But to answer your question, The Cydia you want to use is the one downloaded on your phone after a jailbreak, and download the firmware onto your computer)
imblocko -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 130
Ultimos 30 días: 609
Todo El Tiempo: 45,999
