Introducción
The disassembly of this water kettle can be done by anyone with the help of this manual and the required tools. At one point, you might need and extra pair of hands, so make sure that someone is available when needed.
Qué necesitas
After this, locate the three, already visible screws and unscrew two of the three screws with a PH2 and the other one with a PH 1 screwdriver.
Next, you can detach the black plastic part with the switch after loosening the red wires from the plastic. With this, you can remove the plastic tube as well.
To reassemble the device, follow these instructions in reverse order.
Un agradecimiento especial a estos traductores:
100%
¡ Corey Meyer nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
