Saltar al contenido principal
How to diagnose Samsung Galaxy A40 Charging Problems
Resumen del Video
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: paso 1, imagen 1 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: paso 1, imagen 2 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: paso 1, imagen 3 de 3
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: paso 2, imagen 1 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: paso 2, imagen 2 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: paso 2, imagen 3 de 3
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: paso 3, imagen 1 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: paso 3, imagen 2 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: paso 3, imagen 3 de 3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: paso 4, imagen 1 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: paso 4, imagen 2 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: paso 4, imagen 3 de 3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: paso 5, imagen 1 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: paso 5, imagen 2 de 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: paso 5, imagen 3 de 3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: paso 6, imagen 1 de 3 How to diagnose Samsung Galaxy A40 Charging Problems: paso 6, imagen 2 de 3 How to diagnose Samsung Galaxy A40 Charging Problems: paso 6, imagen 3 de 3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
Conclusión
4 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,566 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,490 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 45
Ultimos 30 días: 184
Todo El Tiempo: 8,152
