Saltar al contenido principal
How to clear a Epson Stylus Photo 820 paper jam
  1. How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: paso 1, imagen 1 de 2 How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: paso 1, imagen 2 de 2
    • If a paper jam is detected, the middle button will display a red light.
    • Press the red button. This will cause the printer to try to automatically correct the issue.
    • If this works, proceed to step 4. Otherwise, proceed to step 2.
  2. How to clear a Epson Stylus Photo 820 paper jam: paso 2, imagen 1 de 2 How to clear a Epson Stylus Photo 820 paper jam: paso 2, imagen 2 de 2
    • The first step in repair is to attempt to remove the paper jam by pulling it out through the top.
    • Pull the paper slowly, and as straight as possible.
    • If this does not work, proceed to step 3.
  3. How to clear a Epson Stylus Photo 820 paper jam: paso 3, imagen 1 de 2 How to clear a Epson Stylus Photo 820 paper jam: paso 3, imagen 2 de 2
    • Assuming the paper will not come out of the top, assess the paper jam.
    • If the print cartridge is in the way, gently push it to the side.
    • Try to get the full edge of the paper above the metal grating.
    • Gently pull the paper out the of the open hatch.
  4. How to clear a Epson Stylus Photo 820 paper jam: paso 4, imagen 1 de 2 How to clear a Epson Stylus Photo 820 paper jam: paso 4, imagen 2 de 2
    • If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light.
    • If steps 2 or 3 corrected the problem, you will need to press the red button again.
    • This may cause another sheet of paper to be pulled through. Do not be alarmed.
    • This should cause the red light to go out.
Linea de Meta
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 20-68, Walters Spring 2011 Miembro de Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 3,246
