Saltar al contenido principal
How to clear a Canon PIXMA MP190 paper jam
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
  1. How to clear a Canon PIXMA MP190 paper jam, Locate Paper Jam: paso 1, imagen 1 de 2 How to clear a Canon PIXMA MP190 paper jam, Locate Paper Jam: paso 1, imagen 2 de 2
    • For safety ensure that the printer is powered off.
    • Lift the scanning unit until the scanning until support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  2. How to clear a Canon PIXMA MP190 paper jam, Step 2: paso 2, imagen 1 de 2 How to clear a Canon PIXMA MP190 paper jam, Step 2: paso 2, imagen 2 de 2
    • Locate the paper jam.
    • Firmly grasp the end of the paper that is most accessible.
    • Pull the jammed piece of paper from the printer evenly.
  3. How to clear a Canon PIXMA MP190 paper jam, Inspect Printer: paso 3, imagen 1 de 1
    • Inspect the printer thoroughly to ensure that all pieces of paper have been removed.
  4. How to clear a Canon PIXMA MP190 paper jam, Clean Paper Feed Rollers: paso 4, imagen 1 de 1
    • Scrub the paper feed roller using the detailing brush.
    • The roller can be rotated manually so the entire surface of the roller can be cleaned.
  5. How to clear a Canon PIXMA MP190 paper jam, Restore Functionality: paso 5, imagen 1 de 2 How to clear a Canon PIXMA MP190 paper jam, Restore Functionality: paso 5, imagen 2 de 2
    • Lift up the scanning unit and press the scanning unit support inward while lowering the scanning unit.
    • The printer is now ready to print.
Conclusión
2 personas más completaron esta guía.
Equipo
Michigan Tech, Team 1-5, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 7
Todo El Tiempo: 1,213
