Saltar al contenido principal
How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: paso 1, imagen 1 de 2 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: paso 1, imagen 2 de 2
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: paso 2, imagen 1 de 2 How to clear Lexmark Intuition S505 paper jam: paso 2, imagen 2 de 2
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: paso 3, imagen 1 de 1
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: paso 4, imagen 1 de 1
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
Conclusión
Once the paper obstruction is removed, your printer should print smoothly without any problems.
2 personas más completaron esta guía.
Omar
Miembro Desde 01/23/13
111 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-38, Regan Winter 2013 Miembro de Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Miembros
8 Guías creadas
Un comentario
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 16
Todo El Tiempo: 1,652
