Introducción
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
Partes
No se requieren partes.
  1. Slide out back bin by pressing the unmarked button on top of the Roomba.
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. Slide out yellow bar on particle bin to access filter
    • Slide out yellow bar on particle bin to access filter
    • This is the air filter assembly
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
    • Reassemble the air filter assembly and slide the particle bin back into place
Conclusión
3 personas más completaron esta guía.
Scott Leonard
Miembro Desde 05/10/10
439 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 20-6, Maness Fall 2010 Miembro de Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Miembros
3 Guías creadas
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 4,691
