Saltar al contenido principal
How to clean the Samsung SGH-E317 keypad
Qué necesitas
  1. How to clean the Samsung SGH-E317 keypad, Battery: paso 1, imagen 1 de 1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. How to clean the Samsung SGH-E317 keypad, Motherboard: paso 2, imagen 1 de 1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. How to clean the Samsung SGH-E317 keypad: paso 3, imagen 1 de 1
    • Remove the rubber screw cover using your fingernail.
  4. How to clean the Samsung SGH-E317 keypad: paso 4, imagen 1 de 1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. How to clean the Samsung SGH-E317 keypad: paso 5, imagen 1 de 1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. How to clean the Samsung SGH-E317 keypad: paso 6, imagen 1 de 1
    • With the back panel removed, the motherboard should be fully exposed.
  7. How to clean the Samsung SGH-E317 keypad: paso 7, imagen 1 de 2 How to clean the Samsung SGH-E317 keypad: paso 7, imagen 2 de 2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. How to clean the Samsung SGH-E317 keypad: paso 8, imagen 1 de 2 How to clean the Samsung SGH-E317 keypad: paso 8, imagen 2 de 2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. How to clean the Samsung SGH-E317 keypad: paso 9, imagen 1 de 2 How to clean the Samsung SGH-E317 keypad: paso 9, imagen 2 de 2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. How to clean the Samsung SGH-E317 keypad, How to clean the Samsung SGH-E317 keypad: paso 10, imagen 1 de 1
    • After removing motherboard, the phone will look like this.
  11. How to clean the Samsung SGH-E317 keypad: paso 11, imagen 1 de 1
    • Grab the corner of the rubber key pad and lift out slowly.
  12. How to clean the Samsung SGH-E317 keypad: paso 12, imagen 1 de 2 How to clean the Samsung SGH-E317 keypad: paso 12, imagen 2 de 2
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
Conclusión
Una persona más ha completado esta guía.
Joe Cavaletto
Miembro Desde 01/30/11
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-23, Maness Winter 2011 Miembro de Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 966
