Introducción
If coffee is only coming out of one spout or the knob isn't having any effect on the volume of crema, a cleaning may be in order. This guide will show you how to disassemble, clean and reassemble the spout.
Partes
No se requieren partes.
  1. Remove the spout by pressing the button on top and sliding it towards you. Unscrew the two PH#1 screws on the back of the spout. The spout halves should now separate easily but light prying might be necessary.
    • Remove the spout by pressing the button on top and sliding it towards you.
    • Unscrew the two PH#1 screws on the back of the spout.
    • The spout halves should now separate easily but light prying might be necessary.
  2. Remove the spring of the pushbutton. Relaese the Button and remove the black insert off the cup filler. Push off the metal chrome part. Clean it with a small brush and rinse it under water.
    • Remove the spring of the pushbutton. Relaese the Button and remove the black insert off the cup filler.
    • Push off the metal chrome part.
    • Clean it with a small brush and rinse it under water.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Reinstall the metal part on the back cup filler part then insert the black piece. Hold up the black part a little for pushing in the Button.
    • Reinstall the metal part on the back cup filler part then insert the black piece.
    • Hold up the black part a little for pushing in the Button.
    • Then click it trogether and push in the spring.
  5. Click it together, put in the two screws and you are done. :) Click it together, put in the two screws and you are done. :)
    • Click it together, put in the two screws and you are done. :)
Conclusión
2 personas más completaron esta guía.
Schwarzstein
Miembro Desde 15/07/13
2,314 Reputación
14 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 27
Todo El Tiempo: 2,189
