Saltar al contenido principal
How to clean the Magnavox MWD200F optical lens
Qué necesitas
  1. How to clean the Magnavox MWD200F optical lens, Faceplate: paso 1, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to clean the Magnavox MWD200F optical lens: paso 2, imagen 1 de 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to clean the Magnavox MWD200F optical lens: paso 3, imagen 1 de 1
    • Unclip the three latches on the bottom of the device.
  4. How to clean the Magnavox MWD200F optical lens: paso 4, imagen 1 de 1
    • Pull the faceplate off.
  5. How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: paso 5, imagen 1 de 3 How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: paso 5, imagen 2 de 3 How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: paso 5, imagen 3 de 3
    • Locate the optic lens in the middle of the disc drive. Dip a cotton swab in rubbing alcohol and use it to lightly wipe the lens. After the lens is clear of dust and debris, wait a few minutes to let it air dry.
Linea de Meta
2 personas más completaron esta guía.
Brian
Miembro Desde 09/08/11
112 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 2,376
