Introducción
Cleaning drainage stop.
  1. Open the hatch in lower right front with a flat screwdriver. Open the hatch in lower right front with a flat screwdriver.
    • Open the hatch in lower right front with a flat screwdriver.
  2. Bleed out water if you don't want to slosh on the floor. Bleed out water if you don't want to slosh on the floor.
    • Bleed out water if you don't want to slosh on the floor.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Open the plug, and hopefully you will find out why your machine is not emptying water or rinsing effectively. Sometimes there is stuff halfway out the feeding channel coming from the side making the plug hard to screw out. I don't think this piece of hardware and some lint caused my problem though.
    • Open the plug, and hopefully you will find out why your machine is not emptying water or rinsing effectively. Sometimes there is stuff halfway out the feeding channel coming from the side making the plug hard to screw out.
    • I don't think this piece of hardware and some lint caused my problem though.
  5. Check that the wheel in back is able to move, and check that there is no $@$* in the opening to the right.
    • Check that the wheel in back is able to move, and check that there is no $@$* in the opening to the right.
  6. Pit everything back together. Hopefully the machine will rinse better.
    • Pit everything back together. Hopefully the machine will rinse better.
Conclusión
Peter Nelly
Miembro Desde 22/03/18
121 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 42
