Saltar al contenido principal
How to clean Non-functoning buttons on remote
Qué necesitas
  1. How to clean Non-functoning buttons on remote, How to clean Non-functoning buttons on remote: paso 1, imagen 1 de 1
    • For later testing: X marks butttons which still work, O marks buttons that don't.
  2. How to clean Non-functoning buttons on remote: paso 2, imagen 1 de 2 How to clean Non-functoning buttons on remote: paso 2, imagen 2 de 2
    • Open battery housing and remove the batteries
    • Remove the screw located in the center of the battery housing
  3. How to clean Non-functoning buttons on remote: paso 3, imagen 1 de 1
    • Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
  4. How to clean Non-functoning buttons on remote: paso 4, imagen 1 de 2 How to clean Non-functoning buttons on remote: paso 4, imagen 2 de 2
    • Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
    • If necessary, add contact spray or alike to the buttom of the rubber buttons
  5. How to clean Non-functoning buttons on remote: paso 5, imagen 1 de 1
    • After cleaning and before full re-assembly, you might want to try if things improved.
    • Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
    • If the repair worked, you should the red top LED flashing
    • Put it all back together again. (Don't forget the screw in the battery housing.)
    • You might need some new batteries as well
Conclusión
22 personas más completaron esta guía.
andre
Miembro Desde 03/12/12
1,701 Reputación
4 Guías creadas
29 comentarios
Having trouble with the latches. Can you explain the technique you used to pry them open?
Thanks!
bob - Contestar
Hi Bob. Force, brute force. Sorry, I don't have a better advice for you. ;-)
andre -
thanks, I fixed mine using your guide.
surfer - Contestar
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Leon Parsons - Contestar
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
Thierry Paulet - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 51
Todo El Tiempo: 37,500
