Saltar al contenido principal
How to clean Magic Mouse 2
Qué necesitas
  1. How to clean Magic Mouse 2, Basis Clean Up: paso 1, imagen 1 de 2 How to clean Magic Mouse 2, Basis Clean Up: paso 1, imagen 2 de 2
    • Take your (soft) cloth of choice, and rub on the glass, the laser-sensor, and the back metal
    • At this point you can get your cloth damp with your Isopropyl Alcohol or Water
  2. How to clean Magic Mouse 2, Deeper: paso 2, imagen 1 de 2 How to clean Magic Mouse 2, Deeper: paso 2, imagen 2 de 2
    • If you eat at your desk, have a dusty room, or get a lot of stuff on your mouse it can accumulate by the rubber tracks and in the charging port
    • Take your spudger and move it up and down on the sides of the rubber
    • Now carefully take the back (flat edge) and gently put it inside the lightning port. AT YOUR OWN RISK Doing this will help loosen up gunk in the port, and you can lightly tap it against your table to nock stuff out (if there is stuff)
Linea de Meta
Una persona más ha completado esta guía.
Colton Turner
Miembro Desde 08/13/22
324 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 44
Ultimos 30 días: 193
Todo El Tiempo: 807
