Saltar al contenido principal
Introducción
Use this repair guide to clean sticky buttons.
Herramientas
Partes
No se especificaron partes.
  1. Use a slightly damp toothbrush to scrape in between the desired sticky buttons. You can also use a bit of isopropyl alcohol. Make sure toothbrush is not to the point of dripping water when scraping.
    • Use a slightly damp toothbrush to scrape in between the desired sticky buttons. You can also use a bit of isopropyl alcohol.
    • Make sure toothbrush is not to the point of dripping water when scraping.
  2. Dry with a cloth after the sticky residue is removed.
    • Dry with a cloth after the sticky residue is removed.
Linea de Meta
9 personas más completaron esta guía.
Adam
Miembro Desde 20/01/10
755 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 16-29, Maness Winter 2010 Miembro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Miembros
50 Guías creadas
I just used this method to clean sticky buttons on a wireless Xbox 360 controller. The Back, Xbox Guide, Start, X, Y, B, and A buttons were all sticky and unresponsive.
I removed the battery pack and followed the steps, and it worked like a charm. All of the buttons work just fine now except for the Xbox Guide button, which isn't really a big deal anyway.
This method works great. Thanks for making this guide, Adam.
Jeff Laxson - Contestar
Wow. I thought I was going to have to buy a new Wii U Pro Controller, but this fixed my sticky B button. So simple. Thanks for saving me $50, friend.
Trevor Babcock - Contestar
my d-pad needs cleaning, help?
Trace Ruby - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 46
Todo El Tiempo: 25,292
