Saltar al contenido principal
Introducción
This guide will teach you how to clean your EarPods
Herramientas
Partes
No se especificaron partes.
  1. If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
    • If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
  2. Use a toothpick to rub all the holes in the earphone Don't use a pencil, it lets waste or any other metal tool, you can puncture the earpod and ruin it.
    • Use a toothpick to rub all the holes in the earphone
    • Don't use a pencil, it lets waste or any other metal tool, you can puncture the earpod and ruin it.
  3. Repeat the process for the other EarPod Repeat the process for the other EarPod
    • Repeat the process for the other EarPod
  4. Use isopropyl alcohol (rubbing alcohol) to clean the exterior of the EarPod Ignore the fact that the alcohol is in the Earpods' case
    • Use isopropyl alcohol (rubbing alcohol) to clean the exterior of the EarPod
    • Ignore the fact that the alcohol is in the Earpods' case
  5. Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker. Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker.
    • Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker.
  6. Let the EarPods dry for at least 10 minutes before using
    • Let the EarPods dry for at least 10 minutes before using
    • Let the Earpods dry by itself, if you use a fan, a hair dryer, or anything else, you could generate corrosion inside and that will ruin it
Conclusión
Remember to dry your Earpods for 10 minutes.
80 personas más completaron esta guía.
jimenezser
Miembro Desde 29/08/12
3,698 Reputación
4 Guías creadas
31 comentarios
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
jaidityayadav - Contestar
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
allisonbridges1 - Contestar
With saliva? You &&^&^$ disgusting.
Pixel Shibe -
GROSS Saliva? yuck
adrienne adams -
what the &&^& is wrong with you
fisheruwu edits -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 67
Ultimos 7 días: 350
Ultimos 30 días: 1,550
Todo El Tiempo: 381,055
