Saltar al contenido principal
How to check or clean Samsung DVD-P230 buttons
Qué necesitas
  1. How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: paso 1, imagen 1 de 3 How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: paso 1, imagen 2 de 3 How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: paso 1, imagen 3 de 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. How to check or clean Samsung DVD-P230 buttons: paso 2, imagen 1 de 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. How to check or clean Samsung DVD-P230 buttons: paso 3, imagen 1 de 1
    • Unscrew the 3 screws in the back.
  4. How to check or clean Samsung DVD-P230 buttons: paso 4, imagen 1 de 2 How to check or clean Samsung DVD-P230 buttons: paso 4, imagen 2 de 2
    • Pull the outer case upward and then towards you.
  5. How to check or clean Samsung DVD-P230 buttons: paso 5, imagen 1 de 3 How to check or clean Samsung DVD-P230 buttons: paso 5, imagen 2 de 3 How to check or clean Samsung DVD-P230 buttons: paso 5, imagen 3 de 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. How to check or clean Samsung DVD-P230 buttons: paso 6, imagen 1 de 2 How to check or clean Samsung DVD-P230 buttons: paso 6, imagen 2 de 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. How to check or clean Samsung DVD-P230 buttons, Power Cord: paso 7, imagen 1 de 3 How to check or clean Samsung DVD-P230 buttons, Power Cord: paso 7, imagen 2 de 3 How to check or clean Samsung DVD-P230 buttons, Power Cord: paso 7, imagen 3 de 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. How to check or clean Samsung DVD-P230 buttons, Tray: paso 8, imagen 1 de 3 How to check or clean Samsung DVD-P230 buttons, Tray: paso 8, imagen 2 de 3 How to check or clean Samsung DVD-P230 buttons, Tray: paso 8, imagen 3 de 3
    • Remove the three screws holding in the DVD tray
  9. How to check or clean Samsung DVD-P230 buttons: paso 9, imagen 1 de 2 How to check or clean Samsung DVD-P230 buttons: paso 9, imagen 2 de 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. How to check or clean Samsung DVD-P230 buttons: paso 10, imagen 1 de 2 How to check or clean Samsung DVD-P230 buttons: paso 10, imagen 2 de 2
    • Gently lift the DVD tray off of the motherboard.
  11. How to check or clean Samsung DVD-P230 buttons, How to check or clean Samsung DVD-P230 buttons: paso 11, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to make sure all the buttons aren't stuck.
Conclusión
3 personas más completaron esta guía.
Mitchell Hart
Miembro Desde 01/21/11
903 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-30, Regan Winter 2011 Miembro de Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,501
