Saltar al contenido principal
How to check Sony Ericsson W200i battery voltage
Qué necesitas
  1. How to check Sony Ericsson W200i battery voltage, Disassembling Sony Ericsson W200i Battery: paso 1, imagen 1 de 2 How to check Sony Ericsson W200i battery voltage, Disassembling Sony Ericsson W200i Battery: paso 1, imagen 2 de 2
    • Slide the battery cover up and off the phone.
  2. How to check Sony Ericsson W200i battery voltage: paso 2, imagen 1 de 2 How to check Sony Ericsson W200i battery voltage: paso 2, imagen 2 de 2
    • Pop the battery out of its slot by lifting it up.
  3. How to check Sony Ericsson W200i battery voltage, How to check Sony Ericsson W200i battery voltage: paso 3, imagen 1 de 2 How to check Sony Ericsson W200i battery voltage, How to check Sony Ericsson W200i battery voltage: paso 3, imagen 2 de 2
    • Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV.
    • Turn the multimeter on.
  4. How to check Sony Ericsson W200i battery voltage: paso 4, imagen 1 de 1
    • Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
    • Replace the battery if the voltage reads below 2.5 volts.
Conclusión
2 personas más completaron esta guía.
Ryan Waltman
Miembro Desde 01/14/11
111 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-10, Forte Winter 2011 Miembro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 5,396
