Saltar al contenido principal
How to check Magnavox MWD200F fuses
Qué necesitas
  1. How to check Magnavox MWD200F fuses, Faceplate: paso 1, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to check Magnavox MWD200F fuses: paso 2, imagen 1 de 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to check Magnavox MWD200F fuses: paso 3, imagen 1 de 1
    • Unclip the three latches on the bottom of the device.
  4. How to check Magnavox MWD200F fuses: paso 4, imagen 1 de 1
    • Pull the faceplate off.
  5. How to check Magnavox MWD200F fuses, How to check Magnavox MWD200F fuses: paso 5, imagen 1 de 1
    • Now that the device is open, you can check for any blown fuses that may need to be replaced.
Conclusión
Una persona más ha completado esta guía.
Taryn
Miembro Desde 09/15/11
109 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,000
