Saltar al contenido principal
How to change the grips on a golf club
Qué necesitas
  1. How to change the grips on a golf club, Grip: paso 1, imagen 1 de 2 How to change the grips on a golf club, Grip: paso 1, imagen 2 de 2
    • Tighten golf club on vice clamp. Align the golf club so that the club face is vertical.
    • Note: Make sure you place container underneath the grip to catch excess mineral spray in later steps.
  2. How to change the grips on a golf club: paso 2, imagen 1 de 2 How to change the grips on a golf club: paso 2, imagen 2 de 2
    • With the xacto knife cut the old grip off of the club.
    • Remove grip from club.
  3. How to change the grips on a golf club: paso 3, imagen 1 de 2 How to change the grips on a golf club: paso 3, imagen 2 de 2
    • Measure the amount of double-sided tape necessary to cover the area of your grip.
    • Place the tape on the club so that it is centered and an extra inch comes off the end of the club.
  4. How to change the grips on a golf club: paso 4, imagen 1 de 2 How to change the grips on a golf club: paso 4, imagen 2 de 2
    • Squirt mineral spirits on the tape.
    • Make sure you drench the tape in mineral spirits.
    • Note: it is safe to get mineral spirits on your skin, it is non-toxic.
  5. How to change the grips on a golf club: paso 5, imagen 1 de 3 How to change the grips on a golf club: paso 5, imagen 2 de 3 How to change the grips on a golf club: paso 5, imagen 3 de 3
    • While the tape still has mineral spray on it, quickly slide the grip all the way down.
  6. How to change the grips on a golf club: paso 6, imagen 1 de 1
    • Wait 1-2 hours for the mineral spray to dry.
Conclusión
Una persona más ha completado esta guía.
Esteban Ortega
Miembro Desde 04/09/15
147 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 30-2, Green Spring 2015 Miembro de Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 Miembros
4 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 1,052
