Saltar al contenido principal
  1. Install 4 x M3 grub screws to the hanger hub.
    • Install 4 x M3 grub screws to the hanger hub.
    • Don't forget to use Blue Loctite on grub screw thread
  2. Install 4 x M2.5 bolts through the baseplate to hanger hub. Don't forget to use Blue Loctite on threads
    • Install 4 x M2.5 bolts through the baseplate to hanger hub.
    • Don't forget to use Blue Loctite on threads
  3. Cut the motor axle to the 18mm length from the baseplate.
    • Cut the motor axle to the 18mm length from the baseplate.
    • Make sure to cover motor, motor wholes and whole motor with something to prevent metal dust getting into the motor. Magnets easily attracts metal particles inside and can cause shortening.
  4. It is only useful when motor has open areas in the baseplate it minimize grease getting into the motor. Attach stainless steel plate to the motor Apply this step only if motor has keyway
    • It is only useful when motor has open areas in the baseplate it minimize grease getting into the motor.
    • Attach stainless steel plate to the motor
    • Apply this step only if motor has keyway
    • Apply retaining compound like (Loctite 648) to keyway and install in the keyway
  5. Use 3xM3 bolts to attach motor to the baseplate
    • Use 3xM3 bolts to attach motor to the baseplate
  6. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  7. Tighten M2 grub screws on motor gear to secure motor gear on axle. Don't forget to use Blue Loctite on grub screw thread
    • Tighten M2 grub screws on motor gear to secure motor gear on axle.
  8. Mount assembly to hanger
    • Mount assembly to hanger
    • Tighten grub screws to lock assembly in place.
    • Make sure the assemblies are parallel to the wheel.
  9. Add brass washer to axle before mounting wheel hub. Attach wheel hub assembly to axle
    • Add brass washer to axle before mounting wheel hub.
    • Attach wheel hub assembly to axle
    • Baseplate should be parallel to the wheel gear assembly otherwise wheel gear will mesh on angle and will cause negative effects.
  10. Add wheel spacer on axle which helps to keep tension between bearings Add wheel spacer on axle which helps to keep tension between bearings Add wheel spacer on axle which helps to keep tension between bearings
    • Add wheel spacer on axle which helps to keep tension between bearings
  11. Attach wheel to the wheel gear assembly Motor gear and Wheel gear assembly should be always parallel to each in all wheel position. If gears not parallel and at angle it can cause negative effects and product more noise than necessary.
    • Attach wheel to the wheel gear assembly
    • Motor gear and Wheel gear assembly should be always parallel to each in all wheel position. If gears not parallel and at angle it can cause negative effects and product more noise than necessary.
    • Loosen up motor bolts so that motor gear would press wheel gear.
    • Use sheet of paper to drive it through wheel gear and motor gear. Spin wheel to push paper through the gears
    • After meshing is good tighten motor bolts
  12. Remove wheel from wheel gear assembly Put wheel gear into the cover and attach V-ring on the wheel gear. Use some grease on v-ring to make it easier to slide on the cover.
    • Remove wheel from wheel gear assembly
    • Put wheel gear into the cover and attach V-ring on the wheel gear.
    • Use some grease on v-ring to make it easier to slide on the cover.
    • It is good time to apply grease to the gears
    • Use 7xM2 bolts to attach motor cover to baseplate
  13. Use 6xM2.5 bolts to attach motor cover to baseplate Use 6xM2.5 bolts to attach motor cover to baseplate Use 6xM2.5 bolts to attach motor cover to baseplate
    • Use 6xM2.5 bolts to attach motor cover to baseplate
  14. Use same instructions for assembling another side
    • Use same instructions for assembling another side
  15. Do a test spin on the bench to make sure everything is fine and sounds okay
    • Do a test spin on the bench to make sure everything is fine and sounds okay
    • On the first test ride start by slowly accelerating and slowly braking to make sure everything is working fine.
    • If there is some minor vibration happening at specific RPM it can be some misbalance in wheel/gears which should disappear after gears sit down in their place.
Conclusión
Aurimas Niekis
Miembro Desde 26/11/18
695 Reputación
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 14
Últimos 30 Días: 42
Todo El Tiempo: 306
