Saltar al contenido principal
Introducción
Use this guide to apply new adhesive on the Apple Watch Series 1 after opening it up or having the Force Touch Sensor replaced.
  1. Use a plastic opening tool to scrape adhesive off the back of the screen. Use a plastic opening tool to scrape adhesive off the back of the screen.
    • Use a plastic opening tool to scrape adhesive off the back of the screen.
  2. You may be able to peel up the adhesive with tweezers. Once you have all of the pieces of adhesive removed, you may want to use an alcohol soaked q-tip to clean any residue off the back of the screen.
    • You may be able to peel up the adhesive with tweezers.
    • Once you have all of the pieces of adhesive removed, you may want to use an alcohol soaked q-tip to clean any residue off the back of the screen.
  3. Use tweezers to peel the outer ring off of one of the adhesive strip pads.
    • Use tweezers to peel the outer ring off of one of the adhesive strip pads.
    • Be sure to get both the double-sided adhesive and the brown backing paper.
    • Be very careful not to fold, bend, or stretch the adhesive tape, as this will make it too thick to seal the screen without a ridge between the screen and the case.
  4. Lay the backed adhesive tape down on the Force Touch sensor, around the edge of the case where the screen rests. Start in a corner with the tape as close to the corner wall as possible. Press on the brown backing paper with a plastic opening tool to secure the adhesive around the entire perimeter.
    • Lay the backed adhesive tape down on the Force Touch sensor, around the edge of the case where the screen rests.
    • Start in a corner with the tape as close to the corner wall as possible.
    • Press on the brown backing paper with a plastic opening tool to secure the adhesive around the entire perimeter.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Use a plastic opening tool to reconnect the display data and digitizer cable connectors. Be careful not to touch any of the contacts directly, as your finger oils may impede connectivity.
    • Use a plastic opening tool to reconnect the display data and digitizer cable connectors.
    • Be careful not to touch any of the contacts directly, as your finger oils may impede connectivity.
  7. To reinstall the metal bracket, line up the single tab with the slot in the top of the lower half, and slide the bracket down. Snap the upper bracket in place. Snap the upper bracket in place.
    • To reinstall the metal bracket, line up the single tab with the slot in the top of the lower half, and slide the bracket down.
    • Snap the upper bracket in place.
  8. Line the battery connector up with its mate on the cable inside the watch body. Use tweezers to press the two connectors together. Use tweezers to press the two connectors together.
    • Line the battery connector up with its mate on the cable inside the watch body.
    • Use tweezers to press the two connectors together.
  9. Rotate the battery down into its slot, and press it into position. Press the battery down against the S1 to re-adhere it in place. Now is the best time to test powering on your watch—if it doesn't turn on, double check all three connectors and try again.
    • Rotate the battery down into its slot, and press it into position.
    • Press the battery down against the S1 to re-adhere it in place.
    • Now is the best time to test powering on your watch—if it doesn't turn on, double check all three connectors and try again.
  10. Use tweezers to peel off the adhesive backing strip.
    • Use tweezers to peel off the adhesive backing strip.
  11. Move the screen back to the right, folding the display data and digitizer cables neatly. Center the screen over the case and press it down firmly onto the adhesive. Center the screen over the case and press it down firmly onto the adhesive.
    • Move the screen back to the right, folding the display data and digitizer cables neatly.
    • Center the screen over the case and press it down firmly onto the adhesive.
Linea de Meta
18 personas más completaron esta guía.
Tobias Isakeit
Miembro Desde 31/03/14
45,364 Reputación
107 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
104 Miembros
8,384 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 17
Últimos 7 Días: 118
Últimos 30 Días: 486
Todo El Tiempo: 2,486
