Saltar al contenido principal
How to align Razor A steering
Qué necesitas
  1. How to align Razor A steering, How to align Razor A steering: paso 1, imagen 1 de 3 How to align Razor A steering, How to align Razor A steering: paso 1, imagen 2 de 3 How to align Razor A steering, How to align Razor A steering: paso 1, imagen 3 de 3
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
  2. How to align Razor A steering: paso 2, imagen 1 de 2 How to align Razor A steering: paso 2, imagen 2 de 2
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Linea de Meta
16 personas más completaron esta guía.
Jordyn
Miembro Desde 10/09/12
544 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-13, Amido Fall 2012 Miembro de Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Miembros
10 Guías creadas
4 comentarios
This is so unhelpful.
Linh Tran - Contestar
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Contestar
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Contestar
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 27
Ultimos 30 días: 102
Todo El Tiempo: 29,746
