Introducción
Over time, cables running from the shifter to the derailleur stretch, causing the derailleur to not shift properly. This can be fixed by making adjustments to the front derailleur. This involves setting the upper and lower bounds, which determine where the derailleur can travel to. Also, if it has been a long time since the cable itself has been tightened, that may be necessary as well.
Qué necesitas
Shift the front derailleur to the 1st position (smallest cog and closest to the body of the bike)
Adjust the "Low" screw with a screwdriver so the derailleur lines up vertically with the 1st gear.
To tighten the cable, place the derailleur in the 1st gear position. This position requires the least amount of tension on the cable.
Loosen the 6mm hex nut using an Allen wrench just enough to allow the cable to come free.
Pull the cable using your hands as tight as you can. Replace the cable under the screw and tighten the screw by turning it clockwise.
Repeat Step 2 to set the upper bound on the derailleur. Now that the cable is tight, the derailleur will be able to travel further away from the frame of the bike and line up with the 3rd gear.
2 personas más completaron esta guía.
