Saltar al contenido principal
How to Winterize Sprinkler System
  1. How to Winterize Sprinkler System, How to Winterize Sprinkler System: paso 1, imagen 1 de 2 How to Winterize Sprinkler System, How to Winterize Sprinkler System: paso 1, imagen 2 de 2
    • Shut the water supply off to the irrigation system. (usually found in the utility room or basement)
  2. How to Winterize Sprinkler System: paso 2, imagen 1 de 1
    • Obtain an air compressor. (you can rent one from the local Home Depot)
  3. How to Winterize Sprinkler System: paso 3, imagen 1 de 3 How to Winterize Sprinkler System: paso 3, imagen 2 de 3 How to Winterize Sprinkler System: paso 3, imagen 3 de 3
    • Connect a hose to the compressor, and one to the water line (in basement).
  4. How to Winterize Sprinkler System: paso 4, imagen 1 de 1
    • Turn the compressor on.
  5. How to Winterize Sprinkler System: paso 5, imagen 1 de 1
    • Start manually turning on each station of the system one by one.
  6. How to Winterize Sprinkler System: paso 6, imagen 1 de 1
    • Let the air blow the water out for about 2 minutes per station.
  7. How to Winterize Sprinkler System: paso 7, imagen 1 de 3 How to Winterize Sprinkler System: paso 7, imagen 2 de 3 How to Winterize Sprinkler System: paso 7, imagen 3 de 3
    • Unplug the hose from the compressor and the water line.
  8. How to Winterize Sprinkler System: paso 8, imagen 1 de 2 How to Winterize Sprinkler System: paso 8, imagen 2 de 2
    • Turn the air compressor off and then turn the sprinkler system off from the control panel outside.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 606
