Saltar al contenido principal
How to Unplug the Battery
Qué necesitas
  1. How to Unplug the Battery, Bottom Cover: paso 1, imagen 1 de 1
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. How to Unplug the Battery: paso 2, imagen 1 de 2 How to Unplug the Battery: paso 2, imagen 2 de 2
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. How to Unplug the Battery: paso 3, imagen 1 de 1
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. How to Unplug the Battery, How to Unplug the Battery: paso 4, imagen 1 de 3 How to Unplug the Battery, How to Unplug the Battery: paso 4, imagen 2 de 3 How to Unplug the Battery, How to Unplug the Battery: paso 4, imagen 3 de 3
    • Peel back the strip of black tape.
  5. How to Unplug the Battery: paso 5, imagen 1 de 2 How to Unplug the Battery: paso 5, imagen 2 de 2
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
Conclusión
Anna Miller
Miembro Desde 09/26/22
831 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 40
Todo El Tiempo: 458
