Introducción
In the event a plunger or a liquid solution fails to unclog a toilet, a $20 toilet auger can help you avoid a $150-plus plumber visit. A toilet auger, also known as a plumber's snake, is a specialized tool designed to navigate through the twists and turns of a toilet's plumbing system to dislodge and remove obstructions. Toilet augers are also used by professional plumbers. In this comprehensive guide, we will walk you through the step-by-step process of using a toilet auger to effectively and safely unclog a toilet.
Qué necesitas
Turn the auger's handle counterclockwise and pull it towards you to retract the snake.
