Saltar al contenido principal
How to Unclog a Toilet Drainpipe
Qué necesitas
  1. How to Unclog a Toilet Drainpipe, How to Unclog a Toilet Drainpipe: paso 1, imagen 1 de 1
    • Turn off the water supply.
    • The switch of water supply may locate differently depends on different pipe structure. Find it either left or right of toilet bowl on the floor.
  2. How to Unclog a Toilet Drainpipe: paso 2, imagen 1 de 1
    • Flush the toilet in order to empty the water tank and the bowl.
  3. How to Unclog a Toilet Drainpipe: paso 3, imagen 1 de 1
    • Use a sponge or paper towel to clean the water left in the water tank.
    • Make sure you wear the gloves.
  4. How to Unclog a Toilet Drainpipe: paso 4, imagen 1 de 1
    • Remove the water supply pipe from the toilet bowl.
  5. How to Unclog a Toilet Drainpipe: paso 5, imagen 1 de 3 How to Unclog a Toilet Drainpipe: paso 5, imagen 2 de 3 How to Unclog a Toilet Drainpipe: paso 5, imagen 3 de 3
    • Find the floor bolts and remove the decorative cap off the bolts.
    • Remove the bolts with a wrench.
  6. How to Unclog a Toilet Drainpipe: paso 6, imagen 1 de 1
    • After removing the floor bolts, wiggle the bowl and remove it.
    • Remove anything that may be stuck in the pipe.
Conclusión
Una persona más ha completado esta guía.
Chen Liang
Miembro Desde 07/08/20
160 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 70
Todo El Tiempo: 1,207
