Saltar al contenido principal
How to Unclog a Sink without Harsh Chemicals
Qué necesitas
  1. How to Unclog a Sink without Harsh Chemicals, How to Unclog a Sink without Harsh Chemicals: paso 1, imagen 1 de 1
    • Measure two cups of tap water.
    • Pour the tap water into a tea kettle and heat the water until it boils.
    • Boiling water may cause burns. Handle with care. Turn stove off after use.
    • Slowly pour boiling water down the clogged drain.
    • This is to avoid splash back and possible injury.
  2. How to Unclog a Sink without Harsh Chemicals: paso 2, imagen 1 de 2 How to Unclog a Sink without Harsh Chemicals: paso 2, imagen 2 de 2
    • Measure one cup of baking soda.
    • Pour baking soda into a large mixing bowl.
  3. How to Unclog a Sink without Harsh Chemicals: paso 3, imagen 1 de 3 How to Unclog a Sink without Harsh Chemicals: paso 3, imagen 2 de 3 How to Unclog a Sink without Harsh Chemicals: paso 3, imagen 3 de 3
    • Measure one cup of vinegar.
    • Pour vinegar into the bowl with the baking soda.
    • Alternatively, mix in one cup of lemon juice as a substitution for the vinegar.
    • Do not use both vinegar and lemon juice.
    • Use a spatula to mix the contents until they form a paste.
  4. How to Unclog a Sink without Harsh Chemicals: paso 4, imagen 1 de 1
    • Pour the combination down the drain using a spatula.
  5. How to Unclog a Sink without Harsh Chemicals: paso 5, imagen 1 de 1
    • Measure two additional cups of tap water.
    • Allow the water to drain completely.
    • Run the tap for approximately 5 - 10 minutes.
    • It might take more than one attempt to clear the clog. Repeat this procedure as needed.
Linea de Meta
Casper Savoie
Miembro Desde 01/12/22
124 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 33
Todo El Tiempo: 451
