Saltar al contenido principal
How to True a Bent Bicycle Rim Using Common Tools
Qué necesitas
  1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: paso 1, imagen 1 de 1
    • Bring your bike somewhere with ample space so you have room to work.
  2. How to True a Bent Bicycle Rim Using Common Tools: paso 2, imagen 1 de 3 How to True a Bent Bicycle Rim Using Common Tools: paso 2, imagen 2 de 3 How to True a Bent Bicycle Rim Using Common Tools: paso 2, imagen 3 de 3
    • Flip the bike on its seat so the wheel can spin freely.
    • Use the spokes to spin the affected wheel.
    • Continue spinning the wheel until it is clear where the bend is occurring.
  3. How to True a Bent Bicycle Rim Using Common Tools: paso 3, imagen 1 de 2 How to True a Bent Bicycle Rim Using Common Tools: paso 3, imagen 2 de 2
    • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
  4. How to True a Bent Bicycle Rim Using Common Tools: paso 4, imagen 1 de 3 How to True a Bent Bicycle Rim Using Common Tools: paso 4, imagen 2 de 3 How to True a Bent Bicycle Rim Using Common Tools: paso 4, imagen 3 de 3
    • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
  5. How to True a Bent Bicycle Rim Using Common Tools: paso 5, imagen 1 de 2 How to True a Bent Bicycle Rim Using Common Tools: paso 5, imagen 2 de 2
    • Pluck the spoke and listen to the pitch to check its tightness.
    • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
  6. How to True a Bent Bicycle Rim Using Common Tools: paso 6, imagen 1 de 2 How to True a Bent Bicycle Rim Using Common Tools: paso 6, imagen 2 de 2
    • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
  7. How to True a Bent Bicycle Rim Using Common Tools: paso 7, imagen 1 de 1
    • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
    • Repeat the tightening/loosening process accordingly if necessary.
Conclusión
Una persona más ha completado esta guía.
Charles Tweedy
Miembro Desde 04/19/23
163 Reputación
1 Guía escrita
Equipo
UCD-MORRIS-S23S1G4 Miembro de UCD-MORRIS-S23S1G4
Community
Miembros de 2
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 935
