Introducción
Use this guide to track down why your Frigidaire oven will not heat and to replace the failed part. You will confirm incoming power, isolate the faulty circuit, test each component with a multimeter, and install new parts when required. The procedure is completely DIY-friendly and far less expensive than replacing the entire range, but it does involve live 240 V, so pay close attention to every safety notice.
Qué necesitas
Paso 1 Verify surface burners have power
Turn a surface burner knob to its highest setting and wait to see if it glows or heats.
Paso 2 Test broil function to isolate bake circuit
Set the oven to broil and watch for heat from the upper element.
Paso 3 Measure supply voltage at plug or outlet
Set the multimeter to AC volts and partly remove the range plug so the prongs are visible.
Touch one probe to the left hot prong and the other to the center neutral and read about 120 V.
Repeat between the right hot prong and neutral for the second 120 V leg.
Measure directly between the two outer hot prongs and confirm about 240 V.
Paso 4 Inspect and test terminal block
Unplug the range and pull it forward to reach the rear terminal block.
Look for melted plastic, loose screws, or charred wires on the block and cord leads.
Re-energize the range briefly and probe center to each outer post for ~120 V and across both outers for ~240 V.
Paso 5 Visually inspect bake element inside cavity
Open the oven and examine the lower bake element for cracks, blisters, or burn-through spots.
Paso 6 Remove and replace bake element from front
Remove the two screws securing the element mounting plate to the rear wall of the cavity.
Pull the element forward just enough to expose the two spade terminals and wires.
Clamp the wires to the liner so they cannot retract behind the wall.
Slide the terminals off the element, install the new element, and push it back into position.
Reinstall the mounting screws and remove the clamps.
Paso 7 Remove rear panels for component access
Slide the stove away from the wall and unplug it.
Use a quarter-inch nut driver to remove the screws securing the upper and lower rear metal panels.
Lift the panels off, keeping track of their orientation and the screw locations.
Paso 8 Measure bake element resistance
Disconnect one wire from the bake element to isolate it.
Set the multimeter to ohms and touch a probe to each element terminal.
Paso 9 Check oven temperature sensor resistance
Locate the sensor harness near the right-hand middle of the back panel and unplug it.
With the meter on ohms, place probes on the two sensor pins.
Paso 10 Replace oven temperature sensor
Remove the single mounting screw that holds the sensor to the liner.
Rotate or pull the sensor straight out, guiding the harness through the opening.
Match the new sensor’s probe length and connector to the original.
Insert the new sensor, reinstall the screw, and reconnect the harness securely.
Paso 11 Test control board bake output voltage
Clip meter leads to the bake output wires on the control board, referencing your wiring diagram or the yellow and orange leads in the video.
Plug the range in, set the clock, then start a 375 °F bake cycle.
A good board supplies about 240 V AC during the preheat.
Paso 12 Replace control board
Unplug the range and photograph all wire positions on the board for reference.
Use needle nose pliers to pull the five spade wires and the large connector straight off the board.
Support the board while removing the four Phillips screws that secure it to the frame.
Mount the replacement board with the same screws and transfer or apply the new overlay if provided.
Reinstall each wire on its matching labeled terminal, using the photo to verify placement and pressing until fully seated.
Restore power, set the clock, and start a bake cycle to confirm the element energizes correctly.
Paso 13 Replace damaged terminal block
Disconnect power and remove the three 3⁄8 inch nuts securing the cord conductors to the old block.
Unscrew the two mounting screws and the green strap screw to release the block.
Align the new block with the chassis holes and fasten it with the supplied screws.
Reattach the grounding strap if you use a three-wire cord; omit it for a four-wire setup.
Place the range wires on the correct studs and tighten the nuts until there is no side-to-side movement.
Paso 14 Reinstall rear panels and power cord
Position the upper and lower rear panels, aligning their screw holes with the frame.
Install all quarter-inch screws and tighten them evenly.
Secure the power cord lugs to the terminal block posts using the provided hex nuts, then torque snugly.
Push the range back, plug it in, and run a bake cycle to verify full heat.
Paso 15 Check thermal fuse and wiring if heat still absent
Some models include a thermal fuse on the rear sheet-metal; test it for continuity and replace if open.
Trace the wiring harness between the control board and elements for breaks or burnt connectors that need repair.
Your Frigidaire oven should now preheat quickly and hold temperature. Always verify that 240 V is present at the terminal block after completing any wiring repairs and re-check the control board clock after a power cycle. Enjoy getting back to reliable cooking.
