Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
How to Troubleshoot No Heat Issues in an Electric Frigidaire Stove
Vistas: 1.6 k
Ver estadísticas:
Últimas 24 horas:
12
Últimos 7 días:
64
Últimos 30 días:
319
Todo El Tiempo:
1,592
Comentarios: 0
Nadie ha escrito comentarios en esta guía. ¿Quieres escribir el primero?
Ir a los comentarios de la guía
Completado: 0
Nadie ha marcado esta guía como "completada". ¿Quieres marcarla tú?
Favoritos: 0
Nadie ha marcado como "Favorita" ni se ha suscrito a esta guía. ¿Quieres hacerlo tú?
Tiempo Requerido: 45 Minuto - 2 Hora
Dificultad: Moderado
Guía en vídeo Esta guía ha sido transcrita de un vídeo de YouTube.
Introducción
Ir al paso 1 ↓
If your Frigidaire oven won’t heat, or it only warms to under about 200 °F, the problem is often a failed bake element, a bad oven temperature sensor (sometimes called a thermostat), a damaged terminal block or power connection, or a failing control board. This guide walks through simple checks, safe electrical testing, and basic part replacements to restore normal heating without an unnecessary service call.
      • Turn off the range, let it cool completely, and pull it away from the wall so you can access the back.
      • Unplug the power cord before opening panels or disconnecting any wires.
      • Set up a phone to take clear photos of wire positions before removing anything from the control board or terminal block.
      • Wear safety glasses, and wear rubber gloves any time you’re testing live voltage.
      • Treat all wiring as live until you’ve verified the range is unplugged.
      Pregunta a FixBot
      Agregar Comentario
      • Turn a surface burner knob to the highest setting and confirm a burner heats normally.
      • If the cooktop doesn’t heat, troubleshoot the household power supply instead of the oven components.
      • Test the Broil function and check whether the broil element heats.
      • If broil works but bake doesn’t, focus on the bake element and the bake output on the control board.
      • If broil and bake both don’t heat, focus on the control board, wiring, or the incoming 240 V supply.
      Pregunta a FixBot
      Agregar Comentario
      • Set a multimeter to AC voltage.
      • Carefully pull the plug partly out and probe the prongs to check voltage, using rubber gloves.
      • Measure left hot to neutral and right hot to neutral, and expect about 120 V on each leg.
      • Measure left hot to right hot, and expect about 240 V.
      • Fully reset the breaker if voltage is wrong, and call an electrician if voltage stays incorrect after reset.
      • Testing the outlet with the cord unplugged can be safer, but probe contact can be harder to maintain.
      Pregunta a FixBot
      Agregar Comentario
      • Locate the terminal block at the bottom center of the range, and inspect it for burn marks, melted plastic, or loose or damaged wires.
      • Inspect the power cord wires at the terminal block and the three wires leaving the block into the range.
      • If needed, test the terminal block just like the outlet by measuring hot-to-neutral (about 120 V each) and hot-to-hot (about 240 V).
      • Unplug the range after the voltage checks before continuing.
      Pregunta a FixBot
      Agregar Comentario
      • Inspect the bake element inside the oven for visible damage like scorching, charring, cracks, or sections that look exploded.
      • Use a screwdriver to remove the two screws holding the bake element to the rear oven wall.
      • Pull the element toward you a few inches to expose the wire connectors.
      • Clamp the wires in place with a clamp on each side so the connectors don’t slip back through the hole.
      • Disconnect the element from the terminals, swap in a replacement element, reconnect it, and reinstall the two mounting screws.
      • Clamping the wires is critical so you don’t lose the connectors behind the insulation.
      Pregunta a FixBot
      Agregar Comentario
      • Use a 1/4" nut driver or a drill/driver with a 1/4" hex bit to remove the screws holding the rear silver panel(s).
      • Remove only the screws holding the silver panel plates, not similar-looking screws that belong to the chassis.
      • Lift the panel(s) away and set the screws aside for reassembly.
      • Some models have one rear panel, and others have an upper and lower rear panel.
      Pregunta a FixBot
      Agregar Comentario
      • Inspect the bake element wiring harness where it attaches to the element for burned, loose, or damaged connectors.
      • Remove one wire from the bake element so you can test the element by itself.
      • Set a multimeter to ohms resistance and measure across the two element terminals.
      • Replace the bake element if the reading is OL or extremely high, and expect about 10–20 ohms on a good element.
      • Reconnect the wire to the element after testing.
      Pregunta a FixBot
      Agregar Comentario
      • Locate the oven temperature sensor on the right side near the middle of the oven cavity.
      • Unplug the sensor from its harness so you can test the sensor by itself.
      • Set a multimeter to ohms resistance and measure across the sensor terminals.
      • Replace the sensor if it reads OL or if it’s far outside about 1050–1100 ohms.
      • Remove one or two mounting screws, rotate the sensor housing counterclockwise if required, and pull the sensor out.
      • Install the replacement sensor, reinstall the mounting screw(s), and reconnect the wire harness securely.
      • Match the probe length and the harness connection style when choosing a replacement sensor.
      Pregunta a FixBot
      Agregar Comentario
      • Locate the control board and identify the two wires that feed the bake element from the board, which are yellow and orange on the unit shown.
      • Clip multimeter alligator clamps to the two bake-output wires or carefully hold probes on the connections.
      • Plug the range in, set the multimeter to AC voltage, and keep hands clear of exposed terminals.
      • Set the oven clock so it isn’t flashing 12:00, because an unset clock can prevent operation on some models.
      • Set the oven to Bake at about 375–400 and wait for it to click on.
      • Expect about 240 V AC when the board is calling for bake heat, and replace the board if it’s much lower like 160 V or less.
      Pregunta a FixBot
      Agregar Comentario
      • Unplug the range before removing or installing the control board.
      • Take a photo of all wires on the control board, including the large terminal connector at the bottom.
      • Remove the spade connectors from the board, using needle nose pliers if they’re tight.
      • Use a Phillips screwdriver to remove the four Phillips screws holding the control board, and support the board so it doesn’t fall when the last screw comes out.
      • Transfer or install the plastic overlay if needed by peeling the adhesive backing, aligning it to the buttons and display, and pressing firmly.
      • Remove any plastic liner from the overlay before reassembling the control panel.
      • Install the replacement board with the four screws, reconnect all wires by matching the letter and number markings, and set the clock after restoring power.
      • Make sure each spade connector is fully seated with no wiggle room.
      Pregunta a FixBot
      Agregar Comentario
      • Unplug the range and confirm it has no power before servicing the terminal block.
      • Use a 3/8 inch socket wrench to remove the nuts holding the three power cord wires to the terminal block posts.
      • Remove the cord wires from the terminal block and replace any burned wires before reassembly.
      • Remove the screws securing the terminal block to the chassis, including the green ground screw and grounding strap if present.
      • Mount the replacement terminal block using the supported holes on the chassis, because there may be multiple hole patterns.
      • Reinstall the grounding strap unless the range uses a four-wire connector, which doesn’t use the grounding strap.
      • Reinstall the range wiring on the posts and tighten the nuts securely, using 10 AWG wires if replacements are needed.
      Pregunta a FixBot
      Agregar Comentario
      • Reinstall the rear panel(s), align all holes, and reinstall the screws using a 1/4" nut driver or drill/driver with a 1/4" hex bit.
      • Reinstall the power cord onto the terminal block posts and tighten the included hex screws or nuts firmly with a screwdriver or socket wrench.
      • Check the power cord connections for side-to-side play, because looseness commonly leads to overheating and melting.
      • Install a power cord strain relief so the cord can’t pull on the terminal block connections.
      Pregunta a FixBot
      Agregar Comentario
      • Look for a thermal fuse on the back of the range if the oven still won’t heat after the main tests.
      • Test the thermal fuse with a multimeter for continuity and replace it if it doesn’t have continuity.
      • Inspect wiring between the control board and the bake element for broken or burned terminals, especially at exposed metal connectors.
      Pregunta a FixBot
      Agregar Comentario
      • Restore power, set the clock, and run Bake to confirm the bake element heats.
      • Test Broil as well to confirm the range heats in both modes.
      • If you replaced wiring or the terminal block, recheck that all connections are tight after the first heat cycle.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Use the live-voltage checks and component tests together so you can separate a failed bake element, bad sensor, bad board output, or incoming-power problem before replacing the wrong part. After the repair, retest both Bake and Broil and recheck any terminal-block work for tight, cool-running connections. Repair didn't go as planned? Ask our Answers community for help.
Autor
con
Ben Schlichter
Miembro Desde 01/21/25
7,185 Reputación
224 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 64
Ultimos 30 días: 319
Todo El Tiempo: 1,592
