Saltar al contenido principal
How to Tie a Tie: Pratt
Qué necesitas
  1. How to Tie a Tie: Pratt, Preparation: paso 1, imagen 1 de 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Pratt: paso 2, imagen 1 de 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Pratt, Tying: paso 3, imagen 1 de 1
    • Take the active end and cross it under the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Pratt: paso 4, imagen 1 de 1
    • Lift the active end up, so that it is now pointing up.
  5. How to Tie a Tie: Pratt: paso 5, imagen 1 de 2 How to Tie a Tie: Pratt: paso 5, imagen 2 de 2
    • Pull the active end down through the loop around your neck, so that it is now pointing down and to the left.
  6. How to Tie a Tie: Pratt: paso 6, imagen 1 de 1
    • Cross the active end over the front of the knot, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 8.
  7. How to Tie a Tie: Pratt: paso 7, imagen 1 de 1
    • Pull the active end up through the neck loop, so that it is now pointing up.
  8. How to Tie a Tie: Pratt: paso 8, imagen 1 de 2 How to Tie a Tie: Pratt: paso 8, imagen 2 de 2
    • Pull the active end down through the wrap you created in step 6 (see second picture).
  9. How to Tie a Tie: Pratt, Finishing: paso 9, imagen 1 de 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  10. How to Tie a Tie: Pratt: paso 10, imagen 1 de 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  11. How to Tie a Tie: Pratt: paso 11, imagen 1 de 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Conclusión
Congratulations! You've successfully tied the Pratt knot!
3 personas más completaron esta guía.
Wes
Miembro Desde 03/29/17
514 Reputación
2 Guías creadas
Equipo
The Electric Warthogs Miembro de The Electric Warthogs
Community
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 546
