Saltar al contenido principal
How to Take in a Dress by Hand
Qué necesitas
  1. How to Take in a Dress by Hand, How to Take in a Dress by Hand: paso 1, imagen 1 de 1
    • Lay the dress flat on a table.
  2. How to Take in a Dress by Hand: paso 2, imagen 1 de 2 How to Take in a Dress by Hand: paso 2, imagen 2 de 2
    • Measure the bust and waist of the dress with the measuring tape and write the measurements down.
    • Measure your own bust and waist. Subtract the your measurements from the dress measurements.
    • Divide these numbers by two.
    • This is the amount of fabric that will be removed from each side.
  3. How to Take in a Dress by Hand: paso 3, imagen 1 de 1
    • Turn the dress inside out.
    • Use the marker to mark the amount of bust and waist fabric that you are taking in for both sides.
  4. How to Take in a Dress by Hand: paso 4, imagen 1 de 1
    • Connect the marks with sewing pins (or safety pins) to make a clear path to sew along.
  5. How to Take in a Dress by Hand: paso 5, imagen 1 de 3 How to Take in a Dress by Hand: paso 5, imagen 2 de 3 How to Take in a Dress by Hand: paso 5, imagen 3 de 3
    • Thread the needle and leave plenty of excess thread for tying knots.
    • Start at the bottom of the new hem and weave the needle in and out of the dress until you reach the other side.
    • Tie a few knots at the end and cut the excess thread.
    • Now the new hem has been made.
  6. How to Take in a Dress by Hand: paso 6, imagen 1 de 3 How to Take in a Dress by Hand: paso 6, imagen 2 de 3 How to Take in a Dress by Hand: paso 6, imagen 3 de 3
    • Cut off the excess fabric with the fabric scissors. Stay about a centimeter away from the sewed line to make sure you do not cut the thread.
  7. How to Take in a Dress by Hand: paso 7, imagen 1 de 2 How to Take in a Dress by Hand: paso 7, imagen 2 de 2
    • Repeat all of the previous steps on the other side of the dress.
    • Turn your dress inside right, and that completes this guide.
Linea de Meta
Olivia Collins
Miembro Desde 03/23/21
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 46
Ultimos 30 días: 256
Todo El Tiempo: 8,916
