Saltar al contenido principal
How to Stabilize the Stem of a Longwise ES06 E-Scooter
Qué necesitas
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 1, imagen 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 1, imagen 2 de 2
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 2, imagen 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 2, imagen 2 de 2
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 3, imagen 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 3, imagen 2 de 2
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 4, imagen 1 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 4, imagen 2 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 4, imagen 3 de 3
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 5, imagen 1 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 5, imagen 2 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 5, imagen 3 de 3
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 6, imagen 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: paso 6, imagen 2 de 2
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
Conclusión
Maithili Admane
Miembro Desde 09/24/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 55
Todo El Tiempo: 656
