Introducción
Aren’t you tired of having to throw away your brand new belt after finding out it fits you a bit too big? The solution to your dilemma is right here! This guide will walk you through the steps in which you will be able to change the size of your belt to fit you better.
There will only be a couple of items you will need which includes the belt that fits you too big, a hammer, screwdriver, measuring tape, a nail, and scissors. You will start saving your money in no time.
Qué necesitas
Put your belt on.
Using a ruler or measuring tape, measure how much of the belt you want to remove. Make this mark on the buckle end of the belt.
Place a mark where you will cut the belt to shorten it.
Reinsert the screws and screw them back in place using a screwdriver.
Place your belt on a workspace that can be nailed into.
Place a nail on the new spot where you'd like to add a hole.
Hammer the nail until it goes all the way through the belt.
Una persona más ha completado esta guía.
