Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener
Qué necesitas
  1. How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener, How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 1, imagen 1 de 1
    • Face the sharpener showing the side with the blade and screw.
    • Locate the screw on the sharpener.
    Pregunta a FixBot
  2. How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 2, imagen 1 de 3 How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 2, imagen 2 de 3 How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 2, imagen 3 de 3
    • Use the Philips #00 screwdriver to remove the screw.
    Pregunta a FixBot
  3. How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 3, imagen 1 de 2 How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 3, imagen 2 de 2
    • Turn the sharpener on its side to carefully remove the blade from the base of the pencil sharpener.
    Pregunta a FixBot
  4. How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 4, imagen 1 de 3 How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 4, imagen 2 de 3 How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 4, imagen 3 de 3
    • Pour isopropyl alcohol onto a cotton ball.
    • Carefully clean both sides of the blade with the cotton ball to get rid of debris.
    • The blade is sharp. Pinch the blade to stabilize it while using the cotton ball to clean the blade.
    Pregunta a FixBot
  5. How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 5, imagen 1 de 2 How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 5, imagen 2 de 2
    • Carefully sharpen the blade on the sharpening stone by moving the blade up and down numerous times.
    • The sides of the blade are sharp. Hold the dull side of the blade.
    • If you choose to replace the blade instead of sharpen it, you may skip this step.
    Pregunta a FixBot
  6. How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 6, imagen 1 de 2 How to Sharpen the Blade of a Maped Hand-Held (Model 506600) Pencil Sharpener: paso 6, imagen 2 de 2
    • Align the blade to the pencil sharpener.
    • Screw the blade back onto the base of the pencil sharpener.
    Pregunta a FixBot
Conclusión
Jazlyn Liu
Miembro Desde 02/19/25
133 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-3, Andersen Winter 2025 Miembro de UC Davis, Team 2-3, Andersen Winter 2025
UCD-ANDERSEN-W25S2G3
Miembros de 3
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 237
