Saltar al contenido principal
How to Sharpen Troy-Bilt TB110 Lawnmower Blades
Qué necesitas
  1. How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 1, imagen 1 de 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 1, imagen 2 de 2
    • Disconnect the spark plug wire.
    • This step is critical to avoid an accidental startup since we are working on the blade.
  2. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 2, imagen 1 de 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 2, imagen 2 de 2
    • Put saran wrap on the inside of the gas cap.
    • This is done to prevent gas from spilling out when we turn over the lawnmower.
  3. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 3, imagen 1 de 1
    • Turn the lawn mower over on its side.
  4. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 4, imagen 1 de 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 4, imagen 2 de 2
    • Use a 5/8 ratchet or wrench to remove the bolt. Then remove the blade.
    • Note how the blade is oriented on the lawn mower for reassembly.
    • Do not grab it from the sharp parts of the blade.
  5. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 5, imagen 1 de 1
    • Clean the blade with a scraper or a wire brush to remove grass residue .
  6. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 6, imagen 1 de 1
    • Secure the blade in a vice.
  7. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 7, imagen 1 de 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 7, imagen 2 de 2
    • Sharpen the blade with a file or with a grinder. Follow the angle that is already established and move the file along until the edge becomes sharp.
    • Be carful when checking for sharpness. You can very gently run your finger along the edge to check.
    • The blade does not need to be as sharp as a razor blade. Try to make it as sharp as pair of scissors. Check the lawnmower for specific details.
  8. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 8, imagen 1 de 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 8, imagen 2 de 2
    • Put the blade back onto the lawn mower and screw the bolt back on while safely securing the blade.
    • Again be careful not to hold the blade by the sharp edges.
  9. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 9, imagen 1 de 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: paso 9, imagen 2 de 2
    • Flip the lawn mower back to the upright position and remove the saran wrap from the gas cap.
    • Plug the spark plug wire in until you hear a click.
Linea de Meta
Una persona más ha completado esta guía.
Andrew DePari
Miembro Desde 03/24/21
193 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 65
Todo El Tiempo: 1,191
