Saltar al contenido principal
How to Sew a Seam That Has Ripped with a Backstitch
Qué necesitas
  1. How to Sew a Seam That Has Ripped with a Backstitch, How to Sew a Seam That Has Ripped with a Backstitch: paso 1, imagen 1 de 1
    • Before you start fixing that torn seam, it's crucial to investigate the damage first.
    • Flip your clothing inside out and closely examine the rip along the seam. Identify the starting and ending points of the tear. These marks will guide you in resewing the seam to mend it.
    • Remember, this method is only applicable for tears that occur along a seam.
  2. How to Sew a Seam That Has Ripped with a Backstitch: paso 2, imagen 1 de 2 How to Sew a Seam That Has Ripped with a Backstitch: paso 2, imagen 2 de 2
    • Thread your needle with a matching thread. Tie a knot at the end of the thread and trim off any excess with scissors.
    • I've used a contrasting thread here so you can see it.
  3. How to Sew a Seam That Has Ripped with a Backstitch: paso 3, imagen 1 de 3 How to Sew a Seam That Has Ripped with a Backstitch: paso 3, imagen 2 de 3 How to Sew a Seam That Has Ripped with a Backstitch: paso 3, imagen 3 de 3
    • Start your stitch by pushing the needle up through the fabric from the backside.
    • Then, insert the needle slightly ahead of the first stitch and bring it back up through the fabric.
    • Now, push the needle back down through the end point of the first stitch, creating a straight line.
    • Repeat this process, always bringing the needle up slightly ahead of the previous stitch and then pushing it back down through the end of the previous stitch.
  4. How to Sew a Seam That Has Ripped with a Backstitch: paso 4, imagen 1 de 2 How to Sew a Seam That Has Ripped with a Backstitch: paso 4, imagen 2 de 2
    • Continue sewing in this manner until you reach the end of your seam.
    • To finish, make a small backstitch at the end and secure the thread with a knot on the underside of the fabric.
  5. How to Sew a Seam That Has Ripped with a Backstitch: paso 5, imagen 1 de 1
    • Inspect the ripped seam by turning the garment inside out. Check for any missed stitches or areas that seem insecure.
    • If necessary, turn the garment inside out again and add more backstitches until you're satisfied with the repair.
Conclusión
Smooth out your garment with an iron, paying particular attention to the area where the seam was ripped.
Una persona más ha completado esta guía.
Madelyn Yanez
Miembro Desde 03/25/24
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 39
