Saltar al contenido principal
How to Sew a Hole in a Sock
Qué necesitas
  1. How to Sew a Hole in a Sock, How to Sew a Hole in a Sock: paso 1, imagen 1 de 1
    • Cut about 15 inches of thread in a similar color to your sock.
  2. How to Sew a Hole in a Sock: paso 2, imagen 1 de 3 How to Sew a Hole in a Sock: paso 2, imagen 2 de 3 How to Sew a Hole in a Sock: paso 2, imagen 3 de 3
    • Pass the thread through the needle’s hole and knot it at the end.
  3. How to Sew a Hole in a Sock: paso 3, imagen 1 de 2 How to Sew a Hole in a Sock: paso 3, imagen 2 de 2
    • Turn the sock inside-out.
    • Flatten the sock.
  4. How to Sew a Hole in a Sock: paso 4, imagen 1 de 2 How to Sew a Hole in a Sock: paso 4, imagen 2 de 2
    • Starting at one corner of the hole, insert the needle through the edge and pull it out the other edge.
  5. How to Sew a Hole in a Sock: paso 5, imagen 1 de 2 How to Sew a Hole in a Sock: paso 5, imagen 2 de 2
    • Repeat Step 4, but now in the opposite direction not too far from the previous stitch.
  6. How to Sew a Hole in a Sock: paso 6, imagen 1 de 2 How to Sew a Hole in a Sock: paso 6, imagen 2 de 2
    • Continue repeating Steps 4 and 5 until you get to the end of the hole.
  7. How to Sew a Hole in a Sock: paso 7, imagen 1 de 1
    • Insert half of the needle and wrap the thread around the needle three times.
  8. How to Sew a Hole in a Sock: paso 8, imagen 1 de 2 How to Sew a Hole in a Sock: paso 8, imagen 2 de 2
    • While holding the thread, send the needle all the way through.
  9. How to Sew a Hole in a Sock: paso 9, imagen 1 de 2 How to Sew a Hole in a Sock: paso 9, imagen 2 de 2
    • Repeat Steps 8 and 9 one last time.
  10. How to Sew a Hole in a Sock: paso 10, imagen 1 de 2 How to Sew a Hole in a Sock: paso 10, imagen 2 de 2
    • Cut the excess thread with the scissors.
  11. How to Sew a Hole in a Sock: paso 11, imagen 1 de 1
    • Turn the sock so the right side is facing outwards.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 59
Todo El Tiempo: 2,669
