Saltar al contenido principal
How to Sew a Hole and reattach zippers to a purse
Qué necesitas
  1. How to Sew a Hole and reattach zippers to a purse, Hole and Zippers: paso 1, imagen 1 de 1
    • Locate the hole.
    • It’s important to analyze the area and make sure you have enough thread to cover the area; more is always better.
  2. How to Sew a Hole and reattach zippers to a purse: paso 2, imagen 1 de 1
    • Get a needle and thread ready to sew and make a knot at the end of the thread.
  3. How to Sew a Hole and reattach zippers to a purse: paso 3, imagen 1 de 2 How to Sew a Hole and reattach zippers to a purse: paso 3, imagen 2 de 2
    • Sew the hole together.
    • Notice that the fabric looks smooth and straight, this is from folding the frayed parts of the fabric inward to make the sewing process easier.
    • Make sure to end your sewing session with a secured knot, and cut off excess thread.
  4. How to Sew a Hole and reattach zippers to a purse: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to grab one side of the opened coil.
  5. How to Sew a Hole and reattach zippers to a purse: paso 5, imagen 1 de 1
    • Locate the detached zipper slider and turn it backwards.
    • This is done while still holding one side of the opened coil.
  6. How to Sew a Hole and reattach zippers to a purse: paso 6, imagen 1 de 1
    • Place one side of the coil inside the zipper slider just a little using tweezers.
  7. How to Sew a Hole and reattach zippers to a purse: paso 7, imagen 1 de 2 How to Sew a Hole and reattach zippers to a purse: paso 7, imagen 2 de 2
    • Grab the other side of the opened coils and place that side inside the zipper slider.
    • Make sure that each of the coils are placed evenly inside the slider.
  8. How to Sew a Hole and reattach zippers to a purse: paso 8, imagen 1 de 2 How to Sew a Hole and reattach zippers to a purse: paso 8, imagen 2 de 2
    • Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
  9. How to Sew a Hole and reattach zippers to a purse: paso 9, imagen 1 de 3 How to Sew a Hole and reattach zippers to a purse: paso 9, imagen 2 de 3 How to Sew a Hole and reattach zippers to a purse: paso 9, imagen 3 de 3
    • Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 35
Todo El Tiempo: 2,310
