Saltar al contenido principal
How to Securely Anchor and Install a Towel Rack
Qué necesitas
  1. How to Securely Anchor and Install a Towel Rack, Towel Rack: paso 1, imagen 1 de 2 How to Securely Anchor and Install a Towel Rack, Towel Rack: paso 1, imagen 2 de 2
    • Disassemble the mounting bracket by first unscrewing the screw from its side.
  2. How to Securely Anchor and Install a Towel Rack: paso 2, imagen 1 de 1
    • Place drywall anchors into the holes.
  3. How to Securely Anchor and Install a Towel Rack: paso 3, imagen 1 de 1
    • Hammer the drywall anchors into the holes.
  4. How to Securely Anchor and Install a Towel Rack: paso 4, imagen 1 de 2 How to Securely Anchor and Install a Towel Rack: paso 4, imagen 2 de 2
    • Place the mounting bracket onto the wall making sure that the hole with "UP" next to it is aligned with the top hole. Screw in a screw through the mounting bracket into the drywall anchors.
  5. How to Securely Anchor and Install a Towel Rack: paso 5, imagen 1 de 1
    • Place the cover over the base of the mounting bracket.
  6. How to Securely Anchor and Install a Towel Rack: paso 6, imagen 1 de 1
    • Insert the towel rack into the hole of the towel rack holder and place the towel rack holder over the bracket.
  7. How to Securely Anchor and Install a Towel Rack: paso 7, imagen 1 de 1
    • Secure the towel rack holder into the bracket by screwing the small screw from step 1 into its hole.
Linea de Meta
Brenton Reece
Miembro Desde 09/27/24
148 Reputación
1 Guía escrita
Equipo
CSU Sacramento, Team 1-10, Laflen Fall 2024 Miembro de CSU Sacramento, Team 1-10, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G10
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 50
Todo El Tiempo: 99
