Saltar al contenido principal
How to Secure a Hook and Eye Fastener Properly
Qué necesitas
  1. How to Secure a Hook and Eye Fastener Properly, How to Secure a Hook and Eye Fastener Properly: paso 1, imagen 1 de 1
    • Cut about 28 inches of thread and fold it in half which would be one loop and the two ends together.
    • Then thread the two ends through the eye of the needle.
  2. How to Secure a Hook and Eye Fastener Properly: paso 2, imagen 1 de 2 How to Secure a Hook and Eye Fastener Properly: paso 2, imagen 2 de 2
    • Slide the needle down the thread until you reach about two inches from the loop.
    • Position the needle between the loop and pull through.
    • This will create a knot at the base of the needle which will make the thread less tangled.
    • Next, pull on both ends of the thread to make them equal length before tying a knot.
  3. How to Secure a Hook and Eye Fastener Properly: paso 3, imagen 1 de 1
    • First, position the hook above the zipper and on the inside fabric, about 3mm from the edge.
  4. How to Secure a Hook and Eye Fastener Properly: paso 4, imagen 1 de 2 How to Secure a Hook and Eye Fastener Properly: paso 4, imagen 2 de 2
    • Remove the hook and start by sewing a stitch where your hook was.
    • Then trim the extra thread close to the knot.
  5. How to Secure a Hook and Eye Fastener Properly: paso 5, imagen 1 de 2 How to Secure a Hook and Eye Fastener Properly: paso 5, imagen 2 de 2
    • Sew on top of the knot three times to make sure it is secure.
    • Position the hook on top of the stitch.
    • Anchor the front part of the hook down by sewing over the bottom edge of the hook three times.
  6. How to Secure a Hook and Eye Fastener Properly: paso 6, imagen 1 de 1
    • Then poke the needle underneath the fabric and bring it up in one of the holes.
  7. How to Secure a Hook and Eye Fastener Properly: paso 7, imagen 1 de 2 How to Secure a Hook and Eye Fastener Properly: paso 7, imagen 2 de 2
    • Now hold the other eye of the hook in place.
    • The needle is going to go in from the outside of the wired edge to inside the circle and pull that through till you get a small loop.
    • After that push, the needle through that loop and pull which create a small knot.
    • Now repeat this stitch two more times.
  8. How to Secure a Hook and Eye Fastener Properly: paso 8, imagen 1 de 1
    • Then take the needle into the other hole, coming up in the center.
  9. How to Secure a Hook and Eye Fastener Properly: paso 9, imagen 1 de 1
    • Then repeat step 7 for this hole.
  10. How to Secure a Hook and Eye Fastener Properly: paso 10, imagen 1 de 1
    • After this, tie a knot.
    • Then cut the thread and tie a knot at the end of the thread.
  11. How to Secure a Hook and Eye Fastener Properly: paso 11, imagen 1 de 1
    • To position the eyes, place the hook and eyes together and line up the fabric so the edges match.
  12. How to Secure a Hook and Eye Fastener Properly: paso 12, imagen 1 de 2 How to Secure a Hook and Eye Fastener Properly: paso 12, imagen 2 de 2
    • Hold it in place with your fingers. Start by stitching across the wire and trim the tail near the knot.
    • Sew on top of the knot and the wire three times to make sure it is secure.
    • Making sure you come out from the middle of the eyes.
  13. How to Secure a Hook and Eye Fastener Properly: paso 13, imagen 1 de 1
    • After this, repeat step 7.
  14. How to Secure a Hook and Eye Fastener Properly: paso 14, imagen 1 de 2 How to Secure a Hook and Eye Fastener Properly: paso 14, imagen 2 de 2
    • Then repeat step 8 and 9.
    • It should look like this at the end.
Linea de Meta
Cecilia
Miembro Desde 05/10/21
229 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 67
Todo El Tiempo: 979
