Saltar al contenido principal
How to Salt Scour a Cast Iron Skillet
Qué necesitas
  1. How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: paso 1, imagen 1 de 3 How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: paso 1, imagen 2 de 3 How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: paso 1, imagen 3 de 3
    • Wet the pan in hot water.
  2. How to Salt Scour a Cast Iron Skillet: paso 2, imagen 1 de 3 How to Salt Scour a Cast Iron Skillet: paso 2, imagen 2 de 3 How to Salt Scour a Cast Iron Skillet: paso 2, imagen 3 de 3
    • Apply coarse salt and scrub the pan with a damp dish towel until the pan is stripped of rust and surface particles.
  3. How to Salt Scour a Cast Iron Skillet: paso 3, imagen 1 de 3 How to Salt Scour a Cast Iron Skillet: paso 3, imagen 2 de 3 How to Salt Scour a Cast Iron Skillet: paso 3, imagen 3 de 3
    • Rinse off the pan in cool water and wipe dry with a new towel.
  4. How to Salt Scour a Cast Iron Skillet: paso 4, imagen 1 de 3 How to Salt Scour a Cast Iron Skillet: paso 4, imagen 2 de 3 How to Salt Scour a Cast Iron Skillet: paso 4, imagen 3 de 3
    • Evenly apply the cooking oil spray coat to the pan and wipe away excess oil.
  5. How to Salt Scour a Cast Iron Skillet: paso 5, imagen 1 de 3 How to Salt Scour a Cast Iron Skillet: paso 5, imagen 2 de 3 How to Salt Scour a Cast Iron Skillet: paso 5, imagen 3 de 3
    • Bake-in coating at 450 degrees Fahrenheit for one hour.
  6. How to Salt Scour a Cast Iron Skillet: paso 6, imagen 1 de 2 How to Salt Scour a Cast Iron Skillet: paso 6, imagen 2 de 2
    • Allow to cool for 20 minutes.
Conclusión
The steps provided in this guide have walked you through the process of salt-scouring and re-seasoning a cast iron pan. Now you are ready to cook using a fresh and clean cast-iron pan.
Repeat steps 4-6 if needed to fill in any gaps in the pan that are still bare.
Ethan
Miembro Desde 02/21/23
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 211
